Evo 9 Carbon Front Mitsubishi Emblems
Carbongoodies
Carbongoodies
Ok guys, I'm not sure if I've posted these on here before so just in case, here you go:
Item: Evo 9 Carbon Fibre Front Mitsubishi Emblem.
Price: £35.00 delivered within the UK.
Info: These are a direct replacement for the OEM emblem. They fit inside the OEM carrier plate and replace the silver emblem. They are made entirely from carbon fibre and moulded for a perfect fit, there is no extra plastic carrier plate used so the appearance is just like the OEM emblem but a carbon version. To fit, all you need to do is carefully remove the silver emblem from the OEM carrier plate and stick this in it's place using the 3M tape provided.
Photos:
P
Paulstewart
What is the dimensions of the badge cheers
