Evo 8 Front Right ABS Sensor, Help!
Evo8Frankie
Evo8Frankie
Hi folks, right as im swaping my wheels with another member off MLR i decided to put my car on Axle Stands and take my wheels off for when he arrived, so theres no messing around, so once off, i noticed this black cable with was rapped around the brake line bracket.
And my ABS light was on until i reset the light, and the code told me that the F/R ABS sensor was open/short, im just confirming that this is the F/R ABS housing in the pictures?? and will i need a new hub as this looks knackerd?
thanks.
Evo8Frankie
Evo8Frankie
come on there must be someone that can help,
m7gsr
yes, that's the sensor. Sometimes removing them can cause problems!
Evo8Frankie
Evo8Frankie
yeah ill have to have a look and see if i can remove the snapped part, but ill have to take the hub off and have a look first,
D
Dave8
It's plastic so small screwdriver and hammer!!!
You can just brake them out, it won't knock out whole.
Be very careful putting new one in as they are very tight and you will need to tap them in
But the new one in with grease around it, it will help if it EVER has to come out again. That is one seriously rotten hub carrier though!
Evo8Frankie
Evo8Frankie
yeah mate tell me about it im actully in the middle op sorting both front hubs ect out ie, hameriting them to freshen them up, i did the passenger side yestaday and it looks far better, but thanks for the input mate.:)
