P
ptaroni
after posting up about play in the balance shaft, it appears it only got a bit of play where it meshes into the oil pump drive or something on them lines.. timing belt tensioners are all ok, balance shaft timing is all ok and tension is good. removed all the conrod bearing caps again to double check and they are all ok. really getting to me that i cannot find anything that would cause a knocking noise i have got... it only happens when you rev the engine slightly under a bit of load, causes no loss of power and not metal filings etc in the sump... if anyone has any other ideas then post them up please, ill check anything! if by after the weekend i have still found nothing then i will remove the engine and have it fully checked and rebuilt with forged internals, just means ill be without my evo for a month or two and be driving a fiat punto
thanks again!
