Engine mounts opinions
Powerflex road use or Ralliart ??
Engine, gearbox and both front rear roll center bushes...
gooner8
gooner8
which one the best price? As i would of thought both would be good. :)
For a road car I'd stick to standard Mitsi !
Heard to many reports of engine vibrations being passed through the car creating alot of noise in the cabin
evo arm's m7960
evo arm's m7960
i have compition engine mounts and diff mounts with no balance shafts and a paddle clutch the vibration in the car is insane .
i kind of of like it as it makes the car feel more raw but other hate it :0)
I know someone that's just had a full super pro kit engine, diff, suspension and now he can hardly read what his avcr is displaying cos its shaking so much :)
I have the two powerflex engine mounts, they do the rear transfer one but not a gearbox.
There is a bit of vibration at low revs
Gearbox is same as the upper engine mount :p
They also have 3 choices of stiffness. Road use, normal, track. Yellow, purple, black series... Respectively :D
Although not used ralliart bushes but everyone raves about them over the road
scubaladdie
scubaladdie
I have Powerflex engine and gearbox mounts. Masses of vibration at idle especially with the lumpy idle from my HKS cams. I love it, many won't
Full set must make more of a difference. I wouldn't of said it was that bad a vibration its pulling of slow that does it. What cams are in your car mate?
I thought that all road bushes ended in R on the code? Sure its what powerflex say. Black are meant to be near enough solid aren't they!?
Need to order the gearbox mounts see if they make much difference
Out with the old
and in with the new
:cool:
