Changing oil
D
Digger99
Is there a certain way to change the oil I changed mine on my evo 8 did a engine flush then dropped the oil lefted the plug out then changed the filter when I topped it back up with new oil run it the checked it it was black with old oil again don't no y can anybody help
andyw08
andyw08
skelmersdale lancashire
Its just all the old oil clinging to every thing...if your that concerned and have money to burn do another change in a couple of weeks.....but you'll never get it all out. When was it serviced prior to this one?
kins
kins
North West
You will have old oil trapped in oil cooler and lines. I wouldn't worry about it looking black as it circulates and mixes with the older oil in the system. As long as your using decent oil and filters (of the right spec) and you change it regularly enough then it will be reyt.
D
Digger99
Ok thanks just wasn't sure if there was a certain way to change it that's ok then I put millers in been told it's good for it
