BravuraSpeed
As some of you are aware, we are now the Official Distributor of Silver's products in the UK.
I'm pleased to be able to offer you guys 1 piece and 2 piece discs with 4 pot calipers for our much cherished EVO's.
Product Information
Based on Racing Designs with Proven Track Performance and Suitable for Street.
Caliper Body
Caliper body is forged out of T2024 aluminum, machined from blank
billets.
Brake Pads
Brake pads are made from NAO ceramics (Non Asbestos Organic). Rated at 0~650 degree. Proven to be high friction and low noise.
Heat Shield
All calipers contain a special designed heat shield insulator. These protect against heat transfer from brake pads into the caliper body and piston seals.
Piston
Piston Size of 38/42mm, made of T6061 T6 hard anodized aluminum which is selected for its low heat transfer properties and high resistance to corrosion.
Seals
Only use special Japan made high temperature seals.
Rotor
Constructed from premium grade FC28 carbon iron. Rated at 925 degree.
302/330mm the diameter x 28mm thickness.
All rotors are slotted.
Weight
6.5kg in weight (2piece) / 8.1kg in weight (1piece).
Heat Control
Slotted direction veins help disperse heat to protect the rotor
Full floating hub allows the rotor to expand and contract freely that helps prevent the rotor from warping and cranking. (2piece rotor)
1 piece rotor 330mmx28mm *************650GBP + SHIPPING
2 piece floating rotor kit 330mmx28mm ***********950GBP + SHIPPING
AIR SHIPPING PER KIT IS 150GBP TO YOUR DOOR IN 4-5 WORKING DAYS
We are now looking for a few of you to try a set of these and give some reviews and feedback on the kit for a discounted price. Pm me if interested please.
Product Information
Caliper Body
billets.
Brake Pads
Heat Shield
Piston
Seals
Rotor
Weight
Heat Control
