is there a aftermarket alternative to the oem ayc pump available?
E El_evo5 New Member Messages 2 Location Essex May 19, 2022 #1 is there a aftermarket alternative to the oem ayc pump available?
JimmyT New Member Messages 12 Location Kidderminster in Worcestershire May 23, 2022 #2 From what i understand it can be replaced by a LSD
P phil c New Member Messages 5 Location notts Jun 2, 2022 #3 If you need to replace it ,consider mounting a replacement inside the boot-it will last a lot longer away from the elements
