ABS sensor removal
mikeyb1983
OMG........did not realise they would be stuck in as much as they are.........front one finally out after drilling, hammering and all other things........rear one seems to be even worse as not as accessible.........any ideas on how to make this easier???
P
peter1983r
youre have to drill it out fella only way im afraid
Andy6
Andy6
I used a big Pry-bar but still ended up destroying the sensor
mikeyb1983
Phew......all done two drill bits later and i have finally got a dashboard with no warning lights........!!
Next step MOT again see if i can get the beauty back on the road......i am pretty sure it will fail on a wishbone bush as it looked as if it had a tear in it.....how much are the poly ones and are they easy enough to replace??
