abs sensor/ ayc
mart1983
mart1983
ok, what is going on at the moment is when i put my car away in the garage for about 3 or more days and go to get it to use it my abs light comes on first on start up followed by the ayc about 200 yards down the road. but once i have been driving it for about 10-20mins and turn the car off and then turn it on again everything is fine ( no lights) it only happens from the start!
my question is,
should i go round and clean the sensors or should i found out what the fault is first?
also its only happened in my garage as the garage i had it in before (the in laws) was a bit warmer inside then my cold garage. :hm:
Flash out any fault codes bridge pins 1-3 and check the fluid pal
mart1983
mart1983
hi craig, simon said to do that! it might have to wait until the weekend,gonna be so busy with work till then.. :hm:
mart1983
mart1983
is it 1-3 0r 1-4 pins to bridge? only reason i ask is coz i thought someone said 1-4!:confused:
X
xiii
1-4 mart. Bridge with a split pin or piece of wire and count the flashes. Long flashes are 10s short are 1s. Anyone feel free to correct me.
could be 4 :whistling: only had to do it once so forgot haha
mart1983
mart1983
Ok, cheers lads! Gonna give it a go on Friday..
