ABS Light help - (sensor sezied) work around
Scotlandevo
Hi,
My rear abs sensor has broke off in the hub, my neanderthal actions didn't help this, was seized solid.
Anyway, just put new pads,discs,shoes all round which is brilliant.
Is there a way to switch off the ABS light with the rear sensor not being theire (trick it) in someway as it puts my AYC lights on which annoys me.
I did the fault code check and it brought up OSR sensor.
Thanks in advance
Andy6
Andy6
No there isn't, only solution is to fix it! Even if you could fool it I wouldn't as the AYC/ACD will think one of the wheels isn't rotating and will start sending torque all over the place to compensate I can only imagine the handling would be horrific!
6
6.5ghost
if you still looking I have a whole hub with sensor if you need it. passenger side rear off a evo 6
