ABS Flash sequence
mikeyb1983
Hi guys me AGAIN, nearly there with car now i hope.........one of the wires i had found disconnected was the AYC light and now have managed to get the falsh sequence for ABS light. Just hoping someone can decipher it for me............wanted to get it on the road this week.............any help as always will be appreciated.
Cannot see, to upload mp4 file.......
i have 1 long.......2 short........1 long......3 short.........5 long.......1 short........
any ideas????:thinking:
mikeyb1983
OK so i think i have worked out that it is more than likely. FL and RR speed sensor.........does anyone have these so i can just try it????????
Please correct me if i am wrong though..............
Andy6
Andy6
Getting them out is a nightmare, I mangled one to bits last time I tried. I'd buy new sensors all round if I were you!
mikeyb1983
It appears thoughts they are the most expensive ones out there all others look to be around £70 each and ones for my 5 £130!!! GRRR!
mikeyb1983
Update.........so i thought i would check out the conntections and just make sure they were tight and no damp or anything in them......unplugged and plugged back in the front one. Went to check the rear passenger side and what did i find....???? Someone has cut the plug off both ends and used butt connectors (not very successfully!) to reconnect them together........the wires have been cut to such a length that it will be a nightmare to try and do this again. Is there anyway to fool the system into thinking it has a sensor in it......i.e bridging the wires from car with a fuse????
