a problem engine
richo7256
ok
here is the situation
no 1 problem:
it idles rough when cold ok when warm
what i done:
ran a ecuscan on it and came up with 41 tps open
how do i fix this: i cleared dtc and it didnt come up again with the fault
FAULT STILL THERE
no 2 problem :
tapping sound coming from no1 piston area (closest to timing belt) rocker cover on the front side of the cover (turbo side) ((see pic ))
driven it 1000 miles last week no probems no power loss etc
signs:
dipstick kept flying out new dipstick in its ok
no oil leak
spark plugs are all good (black/brown ground electode and white centre)
no coolant in oil/oil in coolant
complete service new oils (5w30) all done at mitsubishi ralliart garage in germany )
what i have done:
compression test showed 120 (compared to other cylinders 135)
going for a timing belt change on friday booking in now
####can anyone shed anylight onto what the probem or other ways to see if there is more problems with prob no 2??
####how do i change the tps (prob no1):thinking:
thank you everyone very much for taking time to read this
rich
I think you need to either clean or replace your TPS as its basically tell you its open but can't open or close it itself.
The noise is probably the lash adjusters. A VERY popular upgrade is the 3mm holed lash adjusters, they reduce the noise :)
richo7256
wow :shock: didnt expect a answer that fast haha
ok cool
what are lash adjusters where do they go is it easyer to do it same time as timing belt ??
thank you very much steve for that
cheers:D
richo7256
also would they be doing much damage to the engine ???
ok cool
cheers:D
Lash adjuster keeps the gap between the cam and the valve minimal at all times by running oil under pressure into the vessel. They can be done at the same time as the belt, but not necessary :) They won't be doing any damage, just being noisy.
richo7256
ok buddy cheers for the fast response
every day a little wiser haha
thanks
rich
i will come back once i have done it all see if it stopped cheers
