work on car all done
well month i have fitted new cambelt and water pump
new plugs gapped and fitted
last week i stopped the oil leaking through the manifold studs
and done oil and filter change
this week i have replaced my ayc pump and bleed it through
tomorrow i will change the rear diff oils and swap coilovers for some teins :)
monday ill take the car into bristol for a 4 wheel alignment
then next week ill probably change the brake fluid then it will be bath time, car hasnt had a good wax since xmas so its time to get buffing ready for summer :):)
then thats it all work on car done till the next 4.5k service :)
Good effort butty so do you do your own servicing then? I thought Indigo did it. Who does your alignment for you, I think I need mine checking it's a bit twitchy for me, like as if I'm driving a go kart too sensitive
Yes I do mate. Its the best way for me cos even a 4.5k service would cost me over £200 cos id use a tank of fuel getting there and back so what I do is buy my oils etc from ant and do the work myself.
Anything else like mapping etc and buying parts etc I always go straight to him or if I need to go there for something that needs tweaking then I will get him to service it while it there otherwise yea I do it myself.
Car is 10 years old and done 72k now so in my eyes not worth spending all that money when it's easy enough to do myself :)
Oh and I'll probably go to Fcm or pro tyre for alignment :)
True mate just wish I had the patience time and facilities to do it. We still on for getting my lights done b4 japfest? Don't worry will speak to you at fs anyway
good work lee ask fcm for a flagsquad discount. discount code is ella211 ;)
Yes nick whenever your ready just come on over :)
Geof, I know the person that does the alighnment there so Ill get mates rates anyway :):)
well after all the above was done its now time to bin my radiator in favour of a nice new koyrad and mitsi thermostat which was delivered today thanks to antony@indigo-gt :)
will add pics soon
will add pics soon
Told you I saw it when I was there Thursday:whistling:
Mmm hello :wub::):)
Forgot to add that the tein type flex coilovers are now fitted along with the EDFC in car control box
Wow what a difference, nowhere near as much body roll as it had before
And in car control which is hidden in the cubby hole under radio is great for switching from soft around town to hard when you need it at the touch of a button :)
Very nicely done Lee! ;)
How did you get on with the Limp Mode issue in the end???
she was running a bit hot and my ecu has a engine coolant temp rev limit.
basicly the rpm limit was lowered to 3000rpm untill it cooled which explains why it was ok when i left track and went straight for slow drive down the road :)
hence the new rad and thermostat
also just fitted 4 brand new goodyear asymmetrics :)
there goes another £700 :sad:
Marty.H
Christ you spent some recently its how i was with my pulsar. If you dont mind me asking how much was the rad and suspention
cheers
Marty
