foxy lady x
Chief Model
u can't check the clutch unless u take it out, have u checked to see if u have spark at all 4 plugs?
I would also check all ur leads make sure there are no breaks in them, take a plug out take an ignition lead then put the plug into lead, place on a metal part of ur car (exhaust manifold will do) then turn the ignition once to see if u have spark, do that with every plug and every lead, if the spark is weak Change all leads and check again, failing that check coil packs.
Also if ur battery is knackered then it won't start no matter how many attempts at jumping it.
So try a new battery aswell.
Failing that maybe ur starter motor?
wont be starter motor. if that dont work. you should only hear a click from the solonoid.
ECU light on? if so do the flash code check. AND for chirst sake stop turning the engine over with that water leak. Get that sorting overwise youd be turning the engine over with no water, and you'll have no engine left. Get battery on charge too. All that cranking over wears the battery down.
If the Cam pos. sensor has failed the engine will start up and die after one second.
Yea hence why I said only turn it once lol
