L
longeriow
Hi guys, my friend has just bought an Evo 8. She messaged me the spec. What do you recon? Are these mods going to make it a lot faster than standard?
ENGINE
4G63 block and head (non mivec engine)
Custom Billet 94mm Crank
Custom 85.50mm CP pistons
1000+ capable Crower Pro-Series I-Beam Rods
ACL Race Bearings (inc. Thrust washer)
ARP "L-19" heavy duty Head stud Kit
ARP Main Stud Kit
New Mitsubishi oil pump
New Mitsubishi water pump
Balancer shaft removed
1.3 mm HKS head gasket
Head port and polished
Titanium valve springs and retainers
JUN 272 cams
Piper alloy pulleys
JMF intake manifold (polished)
Alloy radiator
Alloy oil cap
Ross sport spark plug cover
Cusco Oil catch tank
Zacklee clear cam cover
TURBO SYSTEM, INTERCOOLER & EXHAUST
AMS True Ball Bearing Turbo GT35
AMS turbo manifold
AMS custom downpipe
Tial 38mm wastegate silver with slip-fit recirc dump
All uprated oil and water lines
AMS intake pipe with K&N filter
AMS 1000 bhp intercooler kit with 3 inch intercooler pipes
Tail dump valve
AMS Race Battery
Trust titanium 3.2 inch exhaust, customised by Primary Designs to remove De-cat
TRANSMISSION, & DRIVE TRAIN
5 speed gsr gearbox re-con(RS GT and 5 speed boxes are all the same strengh just different ratios)
Evo 8/9 rs transfer box with no acd
Evo 8/9 rs rear diff set up
Exedy twin plate clutch
Front and rear Mitsubishi new Wheel hubs
Apr up rated wheel studs, group n rally wheel nuts
SUSPENSION, BRAKES & WHEELS
Ohlins pro spec r coilover suspension
Swift springs and fully adjustable top mounts
Power flex front & rear lower wishbone bushes
Power flex rear upper wishbone bushes
Power flex rear control arm bushes
K-sport 356mm,8 POT brake kit, with ds 2500 pads
K-sport 330mm,6 POT brake kit with ds 2500 pads
Goodridge steel brake lines with kevlar coating front and back
Rays wheels volk racing TE37 time attack 18 inch alloys, 8.5 wide
Toyo t1r tyres 235/40/18
ELECTRONICS & FUELLING
Standard ecu
Additional Bosch 044 with Goodridge -6 lines from filter to pump and pump to rail
1000cc injectors
Aeromotive fuel rail
255 Walbro fuel pump
Apexi avcr boost controller
Electric window switches relocated to centre console
cheers, Longeriow
ENGINE
ARP Main Stud Kit
JUN 272 cams
Piper alloy pulleys
Alloy radiator
Alloy oil cap
AMS turbo manifold
AMS custom downpipe
Tail dump valve
AMS Race Battery
Standard ecu
1000cc injectors
cheers, Longeriow
