Weird boost/fuel cut at 0.7 BAR - EVO 4
P
Pullout1979
am getting a weird boost cut (I think) when I hit around .7 bar. I lose acceleration and start to back fire if I hold the gas pedal down.
I went to a local mechanic and we checked for boost/vacuum leaks and couldn't find anything. Also took a look at the plugs and he saw signs that my car is probably running lean (in his opinion)He recommended a new tps and boost sensor.
Troubleshooting done so far:
-Changed plugs gapped to .026
-Checked battery and alternator
-Set tps to .07V at idle/ played around with different tps settings
-Ordered a new tps that will arrive soon
Next we did some logging on evo scan.
These are 3rd gear pulls at WOT. Boost builds cleanly then cuts out at .7 BAR
I am at a complete loss here, any help would be appreciated
AFR
Link to download logs here: https://drive.google.com/folderview?id=0B1okhUkO4dhuN0pqOVY1cldNRE0&usp=sharing
Bristol
What are you using to log the afr? Has this just started our did you change something? Has the car been mapped? The logs show the tps working so would have said its not that. What does it read at full throttle?
P
Pullout1979
I am using evoscan to log the air I'm not sure where it's getting the info from?
I put on 3 inch cat back exhaust plus a 3 inch test pipe to remove the cat this was about a month ago.
I'm not sure what you mean by mapped? I have not since it's an Evo 4 and the ecu cannot be replaced flashed or mapped
This was foot to the floor full throttle. Sorry if I don't understand your question correctly.
East Yorkshire & Midlands
Need to log 1 byte load as well as to see what loads your hitting on wot, also a wideband is required AFR MAP is no good here, use tps percent rather than volts
Bristol
where are you based?
When logging you only need to select the following items,
RPM,TPS,TimingAdv,Load1Byte,WideBandAF,Load2Byte,InjPulseWidth,InjDutyCycle,KnockSum,WGDC.
it will mean that you'll get a better resolution in your data. You'll need something like an innovate lc-1 to log the afr, as Simon said the AFR is not what the actual fuel is but what the ecu will try and do.
I'm not sure why your knocksum always reads 1 it should read 0.
What ecu do you have in the car? Sorry noticed that its a standard ecu you will need to replace this with a 5 or 6 ecu.
We'd really need to be able to see the load and actual afr before going any further. Depending on the rom he 1byte might not be enabled so you'll have to modify it to record the 2 byte load or select LoadCalculated (and the other items this needs).
The change of exhaust and decat will allow the engine to breathe easier so will mean that you will be getting more load which is why its fuel cutting. You really need to get the car mapped before you cause any damage.
Andy
P
Pullout1979
I live in Vancouver, Canada
The car has the stock ECU and I have no idea where to source a 5 or 6 ECU
We did not enable the load log so I will enable it tomorrow and re try.
I have been running this exhaust for quite awhile just not sure why this is happening now.
Bristol
its more than likely that a change in the weather (getting colder) will cause it due to the air becoming denser
You could source an ecu from the UK and get it shipped, you can also use an ecu from a 7 or 8 but would have to swap a few wires over
P
Pullout1979
Could you point me in the right direction? IE: a specific site etc?
My concern here is that its happening at .7 which is not really fuel cut territory, logging the load could show up a boost leak, have you changed the coil packs? fuel pump?
P
Pullout1979
Coil packs are farely new ~1 year old. Never changed fuel pump. I really need to get a boost leak test done
P
Pullout1979
I made som enew logs with the requested data
Bristol
Drop a walbro 255 pump in, you'll have to drop the tank to do it properly.
The load looks very wrong the 2 byte isn't setup on a standard rom so you'll have to usethe calculated one.
Bristol
Also it looks like your throttle isn't openning fully what does the tps read with out the engine running when you put your foot to the floor?
P
Pullout1979
It reads about 80%
What do you mean by using the calculated one?
Your logging load 2 byte which is not logging correctly give me Rom Id and should be able to give you mut table addresses also wot is max 87, do a static log check wot is 95percent plus
