Evo Rob
Well i started with a VI GSR pretty standard when i got her... went on to this..
Spec..
1999 Mitsubishi Evolution 6
Engine
Air con removed
Turbo back Mongoose Exhaust
Chrome Manifold heat shield
Chrome Power steering heat shield
HKS SSQV
HKS Super Power flow induction kit
HKS Turbo Timer Type 1
Blue custom plug cover
Samco Blue Coolant pipe's
Samco Blue Heater pipe's
Samco Blue Induction Pipe's
Samco Blue Turbo pipe's
Drive train
Helix organic stage 1 clutch
Evo VII Lightweight Fly wheel
Brakes
Alcon 6 pot Calipers up front
Brembo 2 pot rear up rated disc's and pads
Interior
Luke harness
Cobra Imola pro bucket seat
Greedy boost gauge
The rest removed
ICE
Removed
Suspension
Standard from a TME
Wheels and Tyres
18 x 8 Inch AEZ Alloys
25mm Spacers
4 x Pirelli P Zero's
Was going for a single seat track toy but found some rust on the rear of the chassis so had some of the better parts off her and off she went to a breaker...
But before she went i picked this up from a guy on the MLR...
Advertised as a Mitsubishi Lancer Evolution 6 RSX with the Zero Fighter kit
(Still got to check with Xtreme if they have the chassis numbers of the RSX cars they produced..)
Current Spec is..
ARP uprated head and rod bolts
RSII turbo with Essex Turbo's roller bearings and shaft upgrade.
Greddy B spec II boost controller.
Walbro 255 hardwired.
Forge recirc BOV.
3" Mongoose exhaust system turbo back.
Samco Blue hoses
Cusco Oil Catch can.
Upper hard pipe
Alloy intake pipe
Battery relocation kit
Ported and coated manifold
Sard FPR.
Newly painted rocker cover in white.
Reconditioned Brembo brakes in white.
Workmeister Sr2 alloys refurbished in graphite with new goodyear eagle F1 tyres.
Evo VII Exedy uprated organic clutch and flywheel with heavy duty pressure plate.
Upgraded poly bushes throughout but not the engine mounts.
Very clean Evo V Interior and door cards.
Alarm & immobiliser.
Ralliart suspension and topmounts with rear damping control.(Just replaced with BC Coilovers)
Ralliart ECU.
Ralliart Front and rear strut braces.
Ralliart Gearknob.
Ralliart Handbrake lever.
Ralliart mats.
Ralliart brake fluid cover.
Ralliart oil cap.
Ralliart radiator cap.
Ralliart Zero Fighter Side skirts.
Ralliart Zero Fighter front splitter with carbon fibre center section.
Ralliart style mirrors colour coded.
Ralliart Pedal set
Carbon fibre slam panel/air diversion plate.
RS Boot Bar.
As she was when i went to pick her up..
Couldn't resist getting the skirts/splitter and spoiler painted...
Spec..
Engine
Air con removed
HKS SSQV
Drive train
Brakes
Interior
Luke harness
Greedy boost gauge
The rest removed
ICE
Removed
Suspension
Standard from a TME
Wheels and Tyres
25mm Spacers
Current Spec is..
Forge recirc BOV.
Samco Blue hoses
Upper hard pipe
Alloy intake pipe
Sard FPR.
Ralliart ECU.
Ralliart Gearknob.
Ralliart mats.
Ralliart oil cap.
Ralliart Pedal set
RS Boot Bar.
