evo 2 refurb
paulyevo2
paulyevo2
hi got my hands on a lreg evo2 gsr got it cheap as it need alot of work.
the cluch slips lots of broken interior parts broken rear light.
and the list goes on. relocated the boost gauge properly:confused:
first thing is to get it motd then full service inc cambelt diff/gearbox oils
and cluch kit. ive been under it today and its solid no rust whatsoever so
i under sealed her and cleaned/painted calipers discs had a good look round
for the mot rear bushes have gone as well il keep people informed:D
No worries kiddo, you do that!!!
Keep updating this thread as and when you have any news for us. If you have any questions or need advice then post them up on this thread too. Makes things easier all round if it's all in one place;)
Don't forget to add pictures every now and again:D
paulyevo2
paulyevo2
now sorted the ds door wind diflector.
Well the front looks clean enough!!
The bay looks good too;)
I thought you said it was a minger:confused:
paulyevo2
paulyevo2
the pics come out better than the eye.
the main reason i got it is that its a solid car no rust
a good base to work with just macanically a dog at the min.
not going to mod it to much its got new turbo with screemer pipe
new s/s exhaust air filter bleed valve set at 1 bar turbo timer and boost gauge
thats it for now.
list of mods is.
255 fuel pump
digital boost controller set to 1bar.
8mm leads
iridium plugs
stage 2 padle clutch/alloy flywheel.and ill be happy::D
can anyone tell me what bhp roughly ill be running at the flywheel.
A safe bet would be to say around the 290 mark.
Does it have a de-cat or what???
paulyevo2
paulyevo2
it passed mot no probs just warning both rear tyres inner edge near legal limit.
so two tyres and get the 4 wheel alingnment sorted out.
if it still loose at the back get the bushes looked at.
Dave Brennun
Dave Brennun
I love me 1's 2s and 3's, you made a smart choice pal!
If you need bits I have loads but don't tell el because I get um off him:D
I got a RalliArt ECU if you ever feel the need for more power.
paulyevo2
paulyevo2
is that a bolt on or would i need a re map what gains will i get:D
Dave Brennun
Dave Brennun
straight swap over really.
amongst other features; The turbo will kick in at 2.5k instead of the normal 3k.
You will get a stronger sharper boost so no need for an expensive controller (instead you will be better off with a 1.5 bar actuator which will do the trick and they are quite cheap and easy to get hold of).
The fueling on the ECU is already programmed to compensate upto 1.5 bar boost so there wont be any detting going on.
The rad fan will kick in as soon as you start the car and will go off when you drive. It will come back on when you are at stand still in traffic etc and it is set to kick in at a lower temperature then the standard programme to keep the engine temperature running at the pre determined optimum temperature. The fan will stay on whilst the turbo timer is on, if you have one which helps cool everything down at that stage too.
This is a genuine RalliArt ECU and not a programmed unit. When it came out new it retailed at £2800 and is as rare as $2.oo ho!
I am after peanuts for it compared to that obviously!
paulyevo2
paulyevo2
thats more then i paid for my car:eek:
pm me on the price for ecu:)
what boost can std engine safley take on the pulsar it was 1.2 bar
is it around the same on the evo,
paulyevo2
paulyevo2
That's good news to hear buddy!
Make sure you go to some one that is known for tracking cars right and not just any old clown!!!
im lucky i know all the right people with the proper kit having full
alingnment normaly cost around £100.
i know how important it is with a awd car made a big diferance with the r.
paulyevo2
paulyevo2
update things ive done last couple days.
fit new left rear light cluster
rear strut brace
iridium plugs
8.5mm magnecor leads
just got to fit mud flaps when rain stops if it stops.
things on the way
stage 1 clutch kit
s/s manifold cover
change oil/fuel filters
new cambelt kit.
paulyevo2
paulyevo2
fitted the rallyart mud flaps got new cambelt kit allready put some pics up soon.
Not that I have paid THAT MUCH attention but from what I can see:
Mitsi Rear Badge
Flaps on all 4's
HT Leads & Magnecore Sticker
Stainless Heat Shield/Dressing
Brake Light
If I missed anything then it is because of your camera;)
I know that I keep on plugging you stuff buddy, but seeing that Stainless Heat Shield reminded me that I have a nice Chrome Rocker Cover if you are interested???
It will bling that bay out for sure and make your car stand out from the rest as I have only ever come across one Evo that had it and that was in Belgium a good few years back. I was saving it for my next project but if you want it, you know where I am:D
