Red Evo VIII - Long term W.I.P.
Discussion in 'Picture Gallery' started by Kevin Troy, Aug 3, 2014.
Advert:
  1. Kevin Troy
    Kevin Troy New Member
    Aug 3, 2014
    20
    1
    Hi Guys,
    Here is my Evo VIII I bought back in 2009.
    My final goal is to make a bad-ass 2.3 stroker.
    Here are some parts and the work in progress. Hope you don't these much pictures:
    Carbon Cover
    [​IMG]
    [​IMG]
    Wheels Hyper Zero 1 in dimmension 18x9, 5x114,3
    Tires Dunlop SP Sport 235/40 ZR18.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [IMG=http://img181.imageshack.us/img181/6537/p3161623.jpg][/IMG]
    [​IMG]
    Servis;
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Wash
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG] [​IMG]
    [​IMG] [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    HELIX Motorsport Twinclutch
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Washing again
    [​IMG]
    [​IMG]
    New brakediscs
    [​IMG]
    [​IMG]
    2 evo meeting
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Tech info;
    Active Yaw Control (AYC) is an automobile feature that uses an active differential to transfer torque to the wheels that have the best grip on the road.
    Unlike traditional mechanical limited slip differentials, an AYC is electronically controlled.
    AYC was designed by Mitsubishi Motors, first introduced in the Mitsubishi Lancer Evolution IV. It has been included in certain models of every subsequent generation,
    and was also used in the VR-4 variant of the eighth generation Mitsubishi Galant sedan and Legnum wagon. Later developments led to S-AYC (Super-Active Yaw Control),
    first introduced on the Evolution VIII, utilizing a planetary gearset which could support an even greater torque bias than the previous system. AYC and S-AYC have also
    been seen in several Mitsubishi concept cars based on the underpinnings of the Lancer Evo, such as the CZ3 Tarmac and Tarmac Spyder, the Montero Evolution, the RPM 7000,
    and the Concept-X.
    Active yaw control is based on a computer-controlled rear differential which can actively split torque based on input from various accelerometers in the vehicle
    measuring longitudinal and lateral g forces, steering, brakes and throttle position. Where ABS brakes are fitted they too are included in the input parameters.
    It accomplishes this via two hydraulic clutches which can limit torque on individual axles. This system should not be confused with stability control systems which
    utilize the braking system of a vehicle by individually braking certain wheels to rotate and slow the car (such as Electronic Brakeforce Distribution).
    AYC is a performance-oriented system which aims to increase cornering speeds.
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Few nice pic;
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    TUV/MOT;
    [​IMG]
    fi80 exhaust;
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Finished:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Twinclutch:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Light flywheel 4,8kg
    [​IMG]
    1 of 2 discs
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Walbro 255 L/h:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Washing again:
    [​IMG]
    [​IMG]
    Walbro pump 255L/h maunting;
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Old pump;
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    New brakelines HEL Performance;
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Hyper zero-1 rims Powder Coated in white
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Dyno run:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    TEIN Rear Strutbar:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Washing again :)
    [​IMG]
    HEL;
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Electronic Boost solenoid - Tactrix
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Track-day;
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    II. dyno run
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Turbine check;
    [​IMG]
    [​IMG]
    Ultimative car wash :)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Winter setup;
    [​IMG]
    Eibach
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Bilstein B8
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Bilstein & Eibach
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    OEM KYB
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Waxing
    [​IMG]
    After aplying wax:
    [​IMG]
    After wipeing wax:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Oil change
    [​IMG]
    [​IMG]
    OBD Engine check - Clear
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    BOV Cleaning
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Clutch adjustment
    [​IMG]
    Be for
    [​IMG]
    After (pic taken from evolutionm.net)
    [​IMG]
    Viper Performance Silicon Hoses
    [ame=http://www.youtube.com/watch?v=OZjpHrdSubs]Manufacturing of Viper Performance Silicone Hoses, & Pipes LONG VERSION - YouTube[/ame]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Washing
    [​IMG]
    [​IMG]
    [​IMG]
    Enginebay dressup:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    OCC
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Osram Night Breaker Plus HB3 & HB4
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    FP Black, Ceramic Ball Bearing 84mm, ported, 25PSI (1,7 Bar) Waste Gate
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    New Evo 8 Head with exhaust manifold and intake manifold
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Battery relocation
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    - Kelford 272 Cams
    - Kiggly Racing beehive springs & Titanium Retainers
    - Ferrea +1mm intake valves
    - Ferrea +1mm exhaust valves
    - Ferrea Valve locks
    - Ferrea Valve guides
    - Valve stem seals
    - BDL Industries adjustable cam pulleys with ARP bolts
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    OCC 2x
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Night pic
    [​IMG]
    [​IMG]
    Waxing & Detailing
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    EGT Sensor
    [​IMG]
    [​IMG]
    [​IMG]
    Studs
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    SEIBON Carbon fibre TSII Hood
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    4G63 Head Updates
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    NGK BR8EIX
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Rocker cover
    [​IMG]
    [​IMG]
    Head Gaskets
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Photo Shootout
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    CHP
    EVOLUTION VIII HEAD SPEC
    - 4G63 Head work, port & polish
    - Intake Manifold, port & polish, red powder coating
    - Intake Manifold Gasket OEM Mitsubishi
    - Exhaust Manifold, port & polish
    - Exhaust Manifold Gasket OEM Mitsubishi
    - Kelford cams 272, 11 mm valve lift
    - OEM Mitsubishi Cam seals
    - Ferrea +1 mm Inconel Inlet valve
    - Ferrea +1 mm Inconel exhaust valve
    - Ferrea Valve stem seals
    - Kiggly Racing high presure Behive springs
    - Kiggly Racing Titanium retainers
    - BDL Adjustable cam gear
    - ARP Cam gear Sprocket bolts
    - ARP Cam tower bolts
    - Intake & Exhaust studs & locks
    - Forced Performance „Black“ Turbocharger
    Dual ceramic ball bearing, 1,7 bar WGA
    - Ross Sport Turbo Elbow
    - Turbo Elbow Gasket OEM Mitsubishi
    - NGK Spark plugs, Iridium BR8EIX
    - Valve cover, powder coating - Jet black
    - Valve cover Gasket OEM Mitsubishi
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    TB
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Winter SET UP!
    [​IMG]
    [​IMG]
    [​IMG]
    Stickers
    [​IMG]
    [​IMG]
    [​IMG]
    OEM Valves set
    [​IMG]
    [​IMG]
    [​IMG]
    OIL for service
    [​IMG]
    [​IMG]
    Aerocatch Installation
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Evo 9 Headlights
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    CHP Part II
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Alternator Fault
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    NEW Alternator OEM
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    #1
  2. Waffle
    Waffle Member
    Jul 23, 2014
    59
    4
    I love the pics. You must really love it. She's a stunning car bud :)
    #2
  3. DDS789
    DDS789 Well-Known Member
    Jun 20, 2012
    1,430
    277
    I'm gonna have to wait till I have a better internet connection! From what IV seen it looks brilliant! Well done.
    #3
  4. Kevin Troy
    Aug 3, 2014
    20
    1
    thanks guys, yes, I love it ;)
    The 4x4 is a remarkable peace of engineering.
    #4
  5. Kevin Troy
    Aug 3, 2014
    20
    1
    some fresh pic of today :)
    [​IMG]
    [​IMG]
    [​IMG]
    #5
  6. Kevin Troy
    Aug 3, 2014
    20
    1
    Just fitted rear evo 9 lights, looks superb ;)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    #6
  7. Kevin Troy
    Aug 3, 2014
    20
    1
    In meantime receiver NEW 2.3L Engine block, Stroker from ND ;)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    #7
  8. Kevin Troy
    Aug 3, 2014
    20
    1
  9. Kevin Troy
    Aug 3, 2014
    20
    1
  10. Kevin Troy
    Aug 3, 2014
    20
    1
    Finally received Exhaust manifold from JM Fabrications (Rosssport, Thanks guys ;) )
    Quality is amazing/stunning! Runners are 49mm (1,92").
    enjoy the pic :)
    Exhaust manifold JM Fabrications
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    #10
  11. Kevin Troy
    Aug 3, 2014
    20
    1
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    #11
    Arc_81 likes this.
Share This Page
Advert:
