How Much Power Does A Rally Preped Evo X Make
Discussion in 'Motorsport' started by kevin, Sep 10, 2009.
Advert:
  1. kevin
    kevin New Member
    Oct 7, 2008
    62
    1
    ive seen dyno figures for one evo x here in ja...im curious to know what kind of figures they make elsewhere in the world,,both with the 32mm restrictor,,and the 34mm restrictor ...ive seen power figures of 295.88 whp @ 4200rpm; 453ft/lb @ 3350. with 34mm restrictor and stock engine and turbo,,tunned by peter moodie jr.......whos doin more?and whats the spec?
    [​IMG]
    #1
  2. Nick
    Nick Superstar Admin
    Staff Member
    May 6, 2008
    2,392
    151
    Ill have a dig of the rally stuff around here (not that there are many X's) but I must say all these pictures and videos you keep posting your making incredibly jelouse!
    #2
  3. Evo Ash
    Evo Ash New Member
    Mar 7, 2009
    36
    0
    JR Motorsport make Group N X's but i think they run at 300hp also not sure on the torque figures though :confused:
    #3
  4. Tudgey
    Tudgey New Member
    Mar 8, 2011
    124
    0
    i was always sure all rally versions have to be limited to 300bhp.
    #4
  5. m7gsr
    m7gsr New Member
    Sep 1, 2010
    2,696
    67
    +1
    #5
  6. B6lee
    B6lee Community Leader
    Nov 1, 2010
    678
    +2
    #6
  7. Jonny IX
    Jonny IX Group Buy Organiser
    Jun 18, 2010
    2,313
    57
    The BHP must not exceed 300 but torque I think is a free number, engine displacement must also stick to 2000cc in some cases i believe ??
    #7
  8. Nick
    Staff Member
    May 6, 2008
    2,392
    151
    I dont think thats actually true, its more a by product of the other restrictions that are put in place such as the whopping great air flow restricting bung they have to stick it.
    #8
    Dozzer likes this.
  9. m7gsr
    m7gsr New Member
    Sep 1, 2010
    2,696
    67
    Copied from Wikipedia
    Between 1997 and 2010, the regulations mandated that World Rally Cars must have been built upon a production car with a minimum production run of 2500 units. A number of modifications could be made including increasing the engine displacement up to 2.0L, forced induction (including an anti-lag system), addition of four wheel drive, fitment of a sequential gearbox, aerodynamic body modifications, weight reduction to a minimum of 1230 kg and chassis strengthening for greater rigidity.
    Unlike the requirements for the preceding Group A cars, manufacturers were no longer required to build "homologation specials" in order to meet approval. The base model did not need to have all the characteristics of the WRC car, as evidenced from cars such the Peugeot 206, 307, Citroën Xsara and Škoda Fabia, which during this period had no road car variant with a turbocharged petrol engine or four wheel drive.
    Citroën C4 WRC
    To limit power, all forced induction cars were fitted with a 34 mm diameter air restrictor before the turbocharger inlet, limiting the air flow to about 10 cubic meters per minute. The restriction was intended to limited power output to 300 hp although the some WRC engines were believed to produce around 330–340 hp.[citation needed] Engine development did not focus on peak power output but towards producing a very wide powerband (or power curve). Typically, power output in excess of 300 hp was available from 3000 rpm to the 7500 rpm maximum, with a peak of 330–340 hp at around 5500 rpm. At 2000 rpm (the engine idle speed in "stage" mode) power output was slightly above 200 hp.[2]
    #9
  10. kevin
    kevin New Member
    Oct 7, 2008
    62
    1
    im sure JRM are making more than 300whp in there group n evo X's,,,,,more like 320-330whp
    #10
  11. gooner8
    gooner8 Well-Known Member
    Sep 15, 2010
    2,244
    61
    aint Steve hill got a rally evo x?
    #11
  12. e5_dcb
    e5_dcb New Member
    Apr 4, 2011
    96
    0
    HP always around the 300 figure . The torque they get out of them even with restrictors is crazy!
    #12
  13. Silver makinen
    Silver makinen New Member
    Apr 9, 2012
    21
    0
    34mm airflow restrictor designed to limit power unless you use the Toyota Airflow restrictor!
    They were banned from the WRC for using a restrictor that acted like a camera shutter, it opened up after the scrutineers had checked it.
    Cheating barstuards :)
    #13
  14. JRambo
    JRambo New Member
    Mar 26, 2012
    162
    10
    I used to get my evo serviced there, they used the 360 rs. what a car! they used one to pick customers up in, rally spec but 360bhp, my mate worked they and took it out and said it was a weapon!! lol
    #14
Share This Page
Advert:
